Old 01-20-2010, 02:58 AM   #217
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
I know where you meant... is the rubber O-ring still intact? Did you back the regulator out further and then try retightening the nut? If you're getting fuel out of the top of the nut then the seal below is failing... only place i can see where that could happen (I'm looking at one right now).
so your saying the leak has to be from the o-ring or washer? if its not that then it has to be damaged or something?
thank you
cvbikeguy is offline   Reply With Quote
