anybody else have any ideas? The strange thing about this is that when it dies after you boost, you can hear what sounds like a blow off valve coming back through the air filter. Sounds like the compressor surging in a sort, but its not the blow off valve, cause it will do it with it hooked up or unhooked. Also its not the idle air control, we unhooked it while it was running and blocked it, and I feathered the throttle to keep it going, while checking to see if the little orange valve in there was letting boost air creep by. Wasnt it. This thing has me baffled, and the customer is ready to get it back. Thanks for any help!
Ryan
