Originally Posted by knn_is_dope
so i want to know what size and wieght should i go if i want to have stiffer springs and better grip should i get a 180mm 25kg? is that good enough with tokico shocks? i dont want to end up with a soft suspension thank you
drop in a 7mgte, that will lower it with standard springs!!!!!
i did ,king springs ,koni adjustable shocks, big ass sway bars.
stock springs in back,with koni adjustable shocks. you can feeeeel the road and all its impefections!!!!!! OHH ,and every bush under the car replaced also.
