-4 Should be the bottom of the stock turbo gauge if you aren't on the gas on a decent accel it should'nt boost too much, so staying at -4 while cruising is ok. When you do hard accel does it reach what looks like 6.7 lbs of boost? Any shuttering as you let off the gas from hard boost? Basically need more info, but from what I hear there shouldn't be any problems.
