Old 01-25-2010, 12:22 AM   #11
bradenman1
bradenman1 is on a distinguished road
Originally Posted by Benesesso View Post
You already have the valve covers off, so get a GOOD torque wrench and check the head bolt torque. IIRC, stock bolts should be good for ~72 ft. lb., far better than the original 58. Take a good look at a bolt head and see if it says SPS or ARP. Those are aftermarket bolts and will take a little more.
Are the head bolts the big 18mm hex bolts in the spark plug area??
bradenman1 is offline   Reply With Quote
