If they haven't backed out and the gasket hasn't disintegrated then you may have a problem. When the studs pull free (which, sadly, isn't too uncommon) it's the threads in the head which go... not the studs. It'd be great if it were simply a matter of replacing the studs as with the head you have to drill and install helicoils.
