Old 01-27-2010, 03:48 AM   #12
supraluver4life
supraluver4life is on a distinguished road
well i just pulled out the old harness and fixed up another one i had, tested it then installed it. i jumped my car went to start it and nothing.... almost. It would crank over and it seemed like it only fired on one or to cylinders. i pulled out all the spark plugs and the #2 cylinder plug was completely soaked in oil. cleaned them all and put them back in. i also tried swaping around the plug wires on the coils and i still couldnt get anything.
one question. the order for which plug wire goes where on the coils is 1-6-3-4-2-5, and when the car was running well, i mean really well, it was set up 6-1-4-3-5-2. is there a reason it was running like that???
and the cylinders are numbered 1-2-3-4-5-6 front front to rear correct??
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
