Originally Posted by supraluver4life
one question. the order for which plug wire goes where on the coils is 1-6-3-4-2-5, and when the car was running well, i mean really well, it was set up 6-1-4-3-5-2. is there a reason it was running like that???
and the cylinders are numbered 1-2-3-4-5-6 front front to rear correct??
Firing order for a 7MGTE Engine is......
1-5-3-6-2-4
Coil Pack firing order is......
1-6-3-4-2-5
First coil on left, Plug # 1 then # 6 Plug wire into
Middle coil plug # 3 then # 4 plug wire
Third coil on right Plug # 2 then # 5 plug wire
Firing order and coil pack order isnt the same....
yes front to rear. 1 nearest rad.. 6 being the last one.
