Originally Posted by cre
Pulling the spark plugs makes hand turning the crank even easier... and safer.
He right about concerns about compromising a composite head gasket... it's a real concern, but it's far less likely the less you loosen the fasteners... that's why you want to back them off as little as possible. Start with just a quarter turn.
He's wrong about stripping the threads of the head bolts or the CAST IRON block... and his recommended torque value is pretty much stock: 58ft lbs...
He's wrong about not breaking them loose. Do some research on striction and talk to a mechanical engineer about it's effect on torque values. If you love uneven torque and wildly inaccurate readings go for it.
Further more, as there's no lubricant on the threads they're going to have a LOT more friction across all of the connecting surface area... you could honestly torque them past 90 ft lbs and still not reach the same actual clamping force you'll get if you were reinstalling them properly lubed with moly grease and torqued to 75ft lbs. You can help smooth things out a *little* by spraying a GOOD penetrating oil at the base of the head bolt before and after cracking it loose... just soak it... and NO WD-40!
Here's some info I posted about retorquing: http://www.toyota-supra.info/forums/77288-post10.html Also, everyone needs to keep in mind that the torque value you use on the head bolts or studs depends a LOT on what you're using for lubrication.
Yes, you may use sandpaper to clean up the mating surface for the exhaust mani... use a sanding block though and don't sand any more than absolutely necessary. I would use 400 grit sand paper.
ok well ill be looking in to that alot tomorrow im off to sleep and sadly i cant install my mani or turbo untill i get some kind of new threads going and a stud that will fit it... ohh and toyota has my turbo/exhaust manifold gasket and the exhaust manifold stay bolts on back order untill god knows when hopefully ill find out tomorrow or so.
ohh and im being forced to buy new coolant lines as well to keep the warranty on the turbo. ill do some looking for that tomorrow as well
so far im getting that oil line kit from drift motion and ill be looking for a new coolant line kit
thanks ALOT guys you are making a this small nightmare easier for me with this very good information
