Originally Posted by cre
A few points to consider. 1) At's not a CAI unless the filter has a box around it or the filter is placed outside of the engine bay. 2) A LOT of name brand filters let more dirt through than the cheap, crap no-name ones... there were a lot of tests done on these and you can find may reviews. (AEM Dryflow and Apex'i Power Intake were usually the top rated when it comes to both flow and filtering. K&N and HKS were usually the worst for letting a LOT of dirt through)
There are no complete, true CAI kits for the 7M (GE or GTE) that I've ever seen... you will most definitely need to make one. Easy enough though, buy a AMF adapter off E-Bay, add a 90? bent pipe of 2.75" diameter aluminum, add an AEM Dryflow universal filter with 2.75" outlet and place it below the headlight behind the bumper... done.
thank you cre our resident guru.
