Originally Posted by ccwade
I searched thru the posts and I didn't see one that lists the stock specs for the head gasket. Thickness and bore size. Does anyone know if the Fel-Pro part # HS9473PT-1 comes with a MHG and what are the specs to that head gasket? I can't find any info on this.
Any help would be greatly appreciated.
Fel-Pro is similar to Toyota stock, not MHG. You can get MHG from Cometic, HKS, Titan Motor Sports. Depending on the current condition of your head and block will determine what thickness MHG you will need. Your best bet is to consult your machine shop. As for stock and daily use, Fel-Pro is good.
