Dome Light?
Ok here one for you. My dome light want work. 20 Amp fuse on driver side is good, inner door lights work, vanity light on passanger side works. I have power at the wire when grounded to the chassis, but not to the ground wire with it.
If I gound the light unit to the chassis gounds on the light base, the light will work via the switch but not with the doors and the timming on the doors stop, The door lights go out when the door is shut, instead of the nice fade out.
Thanks
SuperX
