Originally Posted by reydio
Fel-Pro is similar to Toyota stock, not MHG. You can get MHG from Cometic, HKS, Titan Motor Sports. Depending on the current condition of your head and block will determine what thickness MHG you will need. Your best bet is to consult your machine shop. As for stock and daily use, Fel-Pro is good.
Does anyone know what the stock thickness of the head gasket is for a 91 turbo? Do you know how I can tell which bore thickness I have on my car?
The description on autoparts warehouse for the felpro kit states that it come with a multilayered metal head gasket.
http://www.autopartswarehouse.com/mm...ket~parts.html
