Guess again. The bolt holes in question are for your front seat belts, not the rear. It's the anchor point for that end of the belt receptacle as well as the guide bar that fit's into the housing on the inside edge of each front seat.
If you've got stock seat belts and the receptacle for the clip isn't anchored at this point on your transmission hump, they aren't installed properly.
