Originally Posted by dylansword
If it is a cracked block, or head or a bhg. Then wouldnt it have low compression?
No, not necessarily. It would fail a leakdown test though.
And there wasnt a bunch of water in the oil, the dip stick looked a little whiter than it should b, and under the cap, was white stuff.
Yup, coolant in oil... that's way too much contamination to be condensation.
You could pressure test the coolant system and see where it starts pouring out of, but it's unnecessary in my opinion...
