Old 08-26-2005, 03:47 PM   #3
monkihead
SP58GT
monkihead's Avatar
Originally posted by Jrok25supra@Aug 14 2005, 09:14 AM
I've been looking around for clutch and flywheel prices and alot of the sites ask for n/a or turbo. Are flywheel and clutches for n/a and turbo the same b/c i have a 86.5 n/a car but plan on putting a turbo engine in it. I think they're the same since n/a and turbo transmissions are direct bolt on for both motors.
i didnt know you asked.
the turbo clutch disk is a little larger than a non turbo but have the same splines.
the pressure plate is a pull type for the turbo, a push for the non turbo.
slave cylinders are different as well.
so, to make it simple, if you have an n/a tranny and hardware use n/a listings. BEWARE! you need to have an upgraded clutch to hold the excess torque and hp you will be pushing to it.
monique- better off dead
