Old 01-30-2010, 06:33 AM   #14
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by bambuko View Post
Yes, but torque starts at a higher point in a larger NA motor, because it comes quicker when you first hit the gas. As I've already said earlier, a FI turbo'd motor can easily put out more torque but there is no way you can rationally argue that a turbo'd engine has the same response and instant torque as a larger naturally aspirated engine.
It appears that we can't come to an agreement. Perhaps you should go over to Toyota and tell them they raced the Supra incorrectly all those years, that a 6 cylinder is the better set up. Or the current Supra hybrid entering in LeMans soon. Or even better, go over to Nissan and tell them the same thing since that's what they also use a NA V8 in their GTR race car!
Or how about this: you're right. Feel better? Good night, chap.
No need to get stressed - I thought we were having a good, objective, friendly discussion. Apologies if I offended you.
Regarding Toyota's super GT racing, or any officially-sanctioned race event, there will be rules. Things like boost, displacement, weight, modifications, etc. are highly regulated. I'm sure Toyota was 'correct' in their setup, based on the rules & restrictions they had at the time. All that said, I wouldn't say they should have run a turbo (even if a rule was the only torque-related reason they didn't) - as I've already stated, turbos aren't ideal for roadracing due to their somewhat inconsistent power delivery relative to rpms.
Life begins at 30psi.
