Old 01-30-2010, 11:21 AM   #2
Green7mgte
Supra Forum Moderator
sounds like a bad fuel pump not putting out enough pressure at low rpms.
thread in the mk3 section were parts of it discuss a bad fuel pump possibility.
Originally Posted by cre
Tyr placing a jumper across FP and B+ in the diagnostic box in the engine bay and then try to start. This bypasses a couple relays and powers the fuel pump directly... it'll help eliminate a bad pump as a possibility.
http://www.toyota-supra.info/forums/...-question.html
Engine error code page from TSRM
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
if not check timing or tps
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
