The fuel pump relay shouldn't even have power if the ignition's off, so I fail to see how this can happen anytime the battery is connected. Is it happening anytime or just with the ignition on?
The relay is a definite possibility. You can jumper FP and B+ in the diagnostic box to power up the pump... this WILL power it full time though, so it's not a solution, just a diagnostic. This bypasses ALL of the power controls in the fuel pump's circuit.
