The wire location in the diagram I said to use are correct. Yes, the PDF you first posted is incomplete as it is missing the Operation portion of the instructions (page 33 forward).
In case you're unaware the 7M-GTE uses a KVAFM (Karman Vortex AFM) and the 7M-GE uses a VAFM (Vane AFM); So, if you end up using different instructions make sure you use the correct instructions (KVAFM).
