what is prolly the most common or are these all about as common. i have replaced the front seal on the crank cause thats where it appeared to be coming from, but i still have the leak. i will pull the cam covers off and clean like crazy and go from there. oh just remembered that the valve cover was loose when i first got the car here i tightened all the bolts to spec. should that still be of concern?
