Old 02-10-2010, 06:35 AM   #1
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Bein honest, you should decide how much you're willing to spend on your car. Your 7m can pull out a reliable 600 with a turbo kit, exhaust mods, and fuel mods (Along with essential odds and ends). A 1jz is the next easiest engine to drop in the MKIII supra in my opinion. Then it would be the 2jz. going with a stand alone ecu system would make any engine really easy to drop in the supra as well.
In the end, any Supra engine can make 600 rwhp reliably and be streetable. Legal, that's iffy depending on where you live, but whatever engine you want to go with can do it. But it's not cheap. Good luck.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
