turbo rebuild, help
so my turbo is blown (makes bad noise, and quite a bit of shaft play) and i was just wondering what was the best rebuild kit for the ct26. any suggestions? i dont really need anything new except for bearings, thrust collar, thrust bearing, thrust spacer, o rings, seal plate, shaft nuts and piston rings (compressor and exhaust side) right?
thank you in advance
oh and what are the best types of metals that these parts are made of?
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
