Thread: 7mgte no spark
Old 02-12-2010, 08:27 PM   #1
supra.7mgte
supra.7mgte is on a distinguished road
Default 7mgte no spark
so i bought a supra a while ago with the engine out and it had a bhg so i replaced that and the head. So i finally got the motor and tranny in and the wiring that i know of and can see done up. when to go start it i had no power at the coil. traced that back to an unplug ignition wire. went to go crank again and still have no spark. so i went to the toyota service manual and went for the no spark condition and started doing testing and found the ignitor to test bad. Replaced the ignitor and i still have no spark.
I am at a lost of what it could be. Any ideas? I know there are guys out there that know alot more about the supras then i do and could prob give me hints on where to start.
By the way its a 1990 supra with a 7mgte. the cylinder head is off a jdm 7mgte and its not running the egr system and it has arp head studs along with the third verison of toyotas gasket
thanks in advance
supra.7mgte is offline   Reply With Quote
