more questions!
I change the radiator today,after I put the new one in I did a test drive on the high way, but the coolant temperature goes high after 9 min about 60 miles/hour so I shut it down and restart it again, the Tem. drop to half and when I start drving it, Temperture goes high again and I DON'T have heater, I used to,I have heater before I change the radiator.
I touch the radiator, it's hot so it means the thermosta is good but the problem is the coolant in the raservior is cold....
