Heated mirrors are standard on all USDM MKIIIs and I believe the same for Canadian MKIIIs.... wish the USDMs had the heated seats option... that'd be nice sometimes.
Nubus, aside from wiring you would need to check the following: 7.5A Gauge fuse, 30A Defrost fuse, 10A Mir. Def. fuse, Defroster relay and defroster switch.... OR, turn the defroster on and test for +12v at the purple wire with the red stripe at the mirror harness and use the white with black stripe for ground.
