well if u just want to got oem replacement there are three verisons of the stock gasket(for canada toyota there is). made sure u get the newest one.and then for like the valve covers cam seals and intake and exhaust i just went to a local parts store and got it... in all i spent about five hundred on gaskets but that includes the head gasket and every single gasket for the top end.
if u use a oem replacement gasket dont torque it to the 58ftlbs that is the factory spec cause u will be in the spot that u r now not to long down the road. i would recommend eighty or eighty five but do torque them in sequence that is is recommend by toyota. i would also recommend arp head studs if u are not sure on wut ur using
