Originally Posted by btwilson86
You said you checked your timing... Are you talking about your valve timing or ignition timing or both?
I thought that goes hand in hand? I used a timing gun to adjust the timing on the belt to about 10 or 11.
And thanks krem, i guess it could be the distributor itself, i sure hope not though. It isnt an exhaust clog cuz i have no Cat, so mabe mechanically the distributor is failing. Ill replace the fuel filter with one i have in the next day or two and see if that helps.
