Originally Posted by Cameroonski
I thought that goes hand in hand? I used a timing gun to adjust the timing on the belt to about 10 or 11.
Not really. The Distributor is directly connected to the exhaust cam, but you still need to verify that the 2 camshafts are timed properly to the crankshaft, and then check your ignition timing again (with the timing light). On the compression stroke, the 2 camshafts have a yellow mark that points straight up (there's a raised line on the cover behind them that you can line them up to) and the crankshaft notch should be right at 0?. Then start the car, idle it to operating temp and shut it off. Put your jumper wire in the diagnostic box and hook up your timing light. Fire the car up and set your base ignition timing to 10? BTDC. Pull the jumper out with the car running and verify that it advances further a couple of degrees, then shut the car off, tighten your dizzy, and disconnect the timing light.
Check here for more info, found this in the MKIII FAQ.
