Originally Posted by supraluver4life
so is it completely necessary to have both the block and head machined when replacing the head gasket with a composite one?
oh and im planning on replacing the timing belt and headgasket at the same time. what would be a good timing belt and a good hg?
I used a Fel-Pro and had the head only machined flat. It was only out a few thousanths. Just get the bolts up to ~70 ft.lb. with the new gasket and you should be OK. I sprayed aluminum paint heavily on both sides of the gasket--never had a problem with any HG I've replaced (~30 or so, only 1 Supra).
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
