Your advice is welcome though cre, even if the engine construction isn't the same as the 7m's, it's pretty close from what I could see of the engine. Plus, listening to you guys here, it gives me other viewpoints to look at the problem. It looks like the rain is going to let up today hopefully, so I'll be able to start pulling it apart today. Thanks for the help.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
