I know how you feel, every few days for the last couple of months it has been raining here in sac. It kind of makes working hard to do, especially when you can't feel your fingers. Good luck with the bearing sound, hopefully it'll clear up soon so you can chase it down.
Ugh, I'll be pulling my motor and trans apart again it seems....Such a drag.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
