If I did a engine swap..
Ok this is what I found.. So is it truly going to be better this route.. I can get this from jdm engine corp. for $2100. Engine, transmission, everything.. Is this truly going to be better for me. I also want to maintain balance on the car. If you say somthing about doing a 1jz then please let me know about the weight differences and if I will need anything... EXTRA.. I mean is it a direct swap, you know.. Somthing simple. I have a guy who could do the complete swap in 2 days for $600. Remember folks, I want direction.. So help me out please.. I will keep looking for more info too.
Used Imported JDM 7M-GTE Turbo 3.0L V6 Toyota Supra 1986 - 1992 Engine & 5 Speed Transmission Swap !
Your Swap Includes The Following:
- Block
- Head
- Turbo
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Throttle Body
- Alternator
- Starter
- Power Steering Pump
- Engine
- 5 Speed Transmission
- ECU
- Wiring
