Here is what I found for the 1jz. Since it is imported I would need a few extra things huh? I was reading about needing some mounts for the transmission. Also needing some other stuff because the engine is imported.. Is this a good idea folks? Going to 1jz like this? They want $2000 for it..
Used Imported JDM 1JZ-GTE Twin Turbo 2.5L Toyota Supra 1989 - 1993 Engine Swap !
Your Swap Includes The Following:
- Block
- Head
- Twin Turbo
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Throttle Body
- Alternator
- Starter
- Power Steering Pump
- Engine
- 5 Speed RWD Transmission
- Wiring Harness
- ECU
- Igniter Chip
