Old 03-02-2010, 04:44 AM   #1
livelaughslide
Default Want MKIV seats in your MKlll???
Figured you guys help me with everything else why not give out some tips and tricks. check out the next thread on gauges!
The front two (driver and passenger) line up 98% so just thread one in couple threads leave tension for the other side then wrench them in. back left (driver side) the bracket is bout and inch too fowerd so either cut out the tab and the factory washer is plunty safe. or find a cleaner way.
now as far as the right (still driver side) its waay over kill, BUT manageable. so drill a hole were it lines up for the factory hole and cut away the rest. i put carpet over mine so it looked clean but the factory wires ARE EVEN THE SAME COLOR! hail toyota. butt conect em and you have power mk4 seats in ur mklll. and you still have a back seat looks killer when the targa's off. i can provide more pics and details if needed but its pretty simple good luck and thanks again for everything!
