Sorry, I can't be of help right now... I checked all of my references and not even the collision repair manual has any usable measurements for determining the angles. My car's lowered as well, so it's not so easy to get under.... hopefully someone with a remotely stock MKIII (they sit nice and high like a small 4x4) will get beck with some measurements.
Actually, the measurements from the ground at the front mount and the same for the rear is all you'll need... then just measure the distance between the two and you can calculate the rest; No special measuring equipment needed.
Can anyone measure those two points?
