im not sure on the turbo stuff at all. im trying to get some info on that. when i put the header on i was have troubles getn it to bolt down all the way flush with the block because it was hitn on the power steering bracket i loosend the bolts on the power steering bracket and had to remove 1. i pushd the bracket forward and it made enough room for it to go flush. im pretty sure it all lines up because ive had it on for a year and havnt had any problems. this is not a turbo header tho its just a regular header not a turbo 1
