Oil leaks and no power
Hi the screws dont need to be that tight, thats why they have those heads ,the gaskets have gone hard from from age and need replaceing, If the engine as a exhaust leak it wont make boost also the cat could be blocked fix the leak then run it with the front pipe off the rest of the system and see if it goes better Phil
