Old 03-06-2010, 08:30 AM   #14
85mkll
85mkll is on a distinguished road
the 2000 gt is pretty much wat started it all for the supras. i know everything is compatible if u change the interals u need to change the head because 1 is 12 and other is 24 valve. the blocks are excactly the same with dif internals evu erything is interchangable and from experince u do not have to grind it down to make the header work loosen the bolts remove 1 thats .closest to the header push it forward and its good dnt waiste ur time grinding it down. ive done alot of research on this stuff. dnt be a dick to the adm. he was just tryn to get more info for the ppl that dnt have a clue wat their doing
85mkll is offline   Reply With Quote
