Old 03-08-2010, 05:44 PM   #19
MA70-3.0GT
MA70-3.0GT's Avatar
Basically then, if the alternator's throwing out any charge then it should be evident across a chassis earth & the lug when the engine's running? I'm getting 11.69 & dropping with higher revs both across earth/alt. lug & across battery terminals. Everything seems to check out continuity wise with my wiring but still no charge. I'm beginning to think reg/rec failure...
Oh, another thing I noticed was after a ten minute drive the other day the casing of the alt was quite hot (if I'd really pressed my hand on hard it would've hurt). To me that says the thing's working but the charge isn't getting past the reg/rec...
