Old 03-09-2010, 12:35 AM   #10
touge_monster86
touge_monster86 is on a distinguished road
i lined the marks on the cam gears to the marks on the metal plate and had the crank mark set to zero. also have the cps with the drill mark lined up to the notch . i think that is right but it could be wrong. the only issue with the hole engine code is that its actually a 7mgte i swapped into an ae86 so im not sure if the code will show up on the cluster or not . and even if it did would the engine actually have to turn over and run in order for it to throw a code .
man i racking my brain. it ran great right before i changed the head gasket
touge_monster86 is offline   Reply With Quote
