Old 03-14-2010, 09:19 PM   #2
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Arrow
This is one I was looking at team. The cost is $2599.
7MGE/7MGTE Stroker Kits Include:
IPP's Forged Crank
Stock Stroke (3.583", 91mm)
New Stroke (3.833", 97.5mm)
Custom Forged Pistons
(any comp & diam)
Forged Steel Pins
(see upgrade option below)
Piston Pin Locks
Plasma Moly Racing Rings
4340 H-Beam Rods
Toga Performance Main Bearings
Toga Performance Rod Bearings
Comes balanced
It's 6.5mm more stroke that when added to the increased bore equals 665cc more cubes of usable power!
Our stroker kit increases torque as much as 30% and 45 Horse Power (much more can be achieved with other HP increasing accessories). This means more pulling and launching power. This can be used with factory FI or Turbos (adjustments in fuel supply may be needed).
After 4 months of Dyno Testing, our non-turbo DOHC motor produced 259 HP and 247lbs of torque. The Turbo produced 320HP and 315 lbs of Torque. Both figures were produced with only the Stroker Kit. As an option, much higher figures can be achieved with additional parts added to the engine.
Stock 1992 Non-Turbo HP is 190 @ 5600rpm 1888 ft/lbs torque .
Turbo is 232 HP @ 5600rpm with 254 torque.
Your engine before & after!
With Original CC's = 2954cc's (Stock Bore 3157cc)
With new Crank .060 = 3271cc's (non-turbo)
That's a 328cc+ increase for Non-Turbo motors!
http://www.importperformanceparts.ne...s_toyota2.html
Supra Saiyan is offline   Reply With Quote
