Originally Posted by Supra Saiyan
I notice on the dash it says TEMS. WFT is this. (Yes I looked around the forums and couldn't find anything)
Also, is it bad to drive it around in only Sport mode?
TEMS is a system built into the Supra that sits on top of the shock. When in either regular or sport mode the TEMS systems can turn the shock to make it lighter or more supportive depending on what you are doing. If you are going fast and break hard, the TEMS system will make the shock harder to assist in keeping control of the car. If you do this, the system lights will go from one to three lights on.
You can keep the car in sport mode if you want, it will just give you a stiffer ride. BUT, the system will only work with the special TEMS shock. If you have a regular shock or strut, it will show that it is doing something, but it is actually doing nothing.
