The erratic idle could also be cause by a misaligned TPS or a failing IDL switch within it. A code 51 while the car is at idle will give that away. AFM is another possibility.
I'd start with checking for stored diagnostic codes: http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
