KYB makes a pretty good damper actually... they make a LOT of OEM shocks too.
I'm pretty sure that the MKIII's dampers are not compatible, but I believe I recall readingof other Toyotas with compatible dampers. You should search the MKII section and its FAQ.
I'm going to move this thread to the MKII section.
