Originally Posted by btwilson86
My first guess on your idle is that you have leaking/broken/misrouted vacuum lines. The brake light is most likely due to low brake fluid.
Also, a little more info may be helpful. Is this a turbo or N/A? Auto or 5 spd? Also, have you checked for any CEL codes?
This is a twin turbo auto, Ok well thanks for the break fluid help i got rid of that problem...this may sound stupid but is the electronic antenna replaceable?
