Thread: 7mgte no spark
Old 03-20-2010, 03:16 PM   #27
supra.7mgte
supra.7mgte is on a distinguished road
well i finally got the harness down and back into the car. got everything hooked up. turned out i was missing one ground that was going to the starter and back feeding power to ecu and the knock sensor was missing as well. The car is no running can some wut drivable. needs a few kinks worked out of it. like the fuel tank and limnes need flushed out(two year old gas) need to get the air out of the cooling and power steering systems. need to install my aftermarket IC and piping along witht the intake. then the interior will go back together and it will go get some exhaust... Im thinking just three inch staight pipe, what do you guys suggest?
supra.7mgte is offline   Reply With Quote
