Old 03-22-2010, 08:20 PM   #1
supraluver4life
supraluver4life is on a distinguished road
Default fuel problem?.... i think
so i have a 1987 toyota supra turbo. fairly stock, full three inch exhaust with a divorced downpipe, new apexi intake filter, and a stage 3 clutch. so my problem i beleive is related to fuel. so heres what happens. when i have around a quarter tank off gas and i go for a hard pull (WOT) it accelerates and then cuts out, then accelerates then cuts out. it does this quite a fe times durring acceleration. then even if i dont floor it, say 1/2 throttle, it does it still does it. its like vroo... vroo... vroo, instead of vroooom! I am really confused about what the problem is. it seems like it is hitting fuel cut but i am only running 6-8 psi. and it only ddoes it when i have 1/4 tank of gas or less (which is most of the time lol). I am thinking maybe the fuel pump is going? but idk. about six months ago it was doing it really bad, when i had more than a half tank of gas. then i changed the fuel filter and it sopped for a few weeks. the filter i pulled out had fairly cleen gas going in one side and on the other side dark redish brown gas came out. after it started happening again, i changed the filter once more. and this did nothing. still does it. but when i pulled out the second filter it wasnt very dirty. so basically what im thinking is that either i have a terribly filthy gasolina tank or my fuel pump is about to hit the shits. im not sure but any feedback about this would be greatly appreciated. thank you in advance!
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
