Old 03-23-2010, 07:29 AM   #1
MarkLinRacing
MarkLinRacing's Avatar
MarkLinRacing is on a distinguished road
Default Knock Sensor/Wiring
So I have my CEL light on.
Pulled the diagnosis code and said something about knock sensor or possibly knock sensor wiring.
I heard from a friend that previously owned a MKIII Supra that apparently these knock sensors on the 7MGTE like to crap out.
I don't want to fix it unless it's causing an issue, currently the car under load, off load and at idle.
Another friend mentioned that my car might be slower than it actually is because the car might be running in "safe mode" because it won't know if it's experiencing knock or not.
I'm not familiar with how these ECUS are programmed. I would appreciate any insight.
Thanks!
MarkLinRacing is offline   Reply With Quote
