it will only be different if you use the turbo pressure plate.
the key here is, u can use the turbo clutch disc, even in upgraded form. just not the pressure plate.
7mge-t + 7mgte clutch disc + 7mge pressure plate, 7mge throwout bearing, 7mge slave cylinder = will work.
centerforce makes a really good clutch, plus ive had mine for about 3 months. im pushing high 200s low 300 hp.
p/n df522018
summit racing will probably the cheapest next to ebay.
monique- better off dead
